Old 07-23-2015, 10:31 PM
CJJeff CJJeff is offline
Default Holley with no choke identification..
Hello all.. trying to identify and document some big block Chevy parts and thinking this engine has a Holley that is not a GM installed part. What is the best way to identify this carb?
Specializing in 1965 to 1970 Musclecars
Old 07-24-2015, 01:37 AM
VintageMusclecar's Avatar
Default Re: Holley with no choke identification..
If the throttle blades are 180's, that appears to be a Holley 9381 which is an 830 cfm carb. The annular boosters are a telltale sign.
Old 07-24-2015, 01:07 PM
earntaz earntaz is offline
Puddle dumper w/annular boosters -- may be a dead giveaway Eric
Old 07-24-2015, 01:25 PM
markjohnson's Avatar
Those annular booster Holleys are very snappy. I like them quite a bit.
Old 07-24-2015, 02:16 PM
Yup -- takes a bit from the CFM, but IMHO, the response is enhanced ... TAZ
Old 07-24-2015, 02:25 PM
Day2_69Z Day2_69Z is offline
What are the metering plates coded as ?
Old 07-24-2015, 05:02 PM
69 Post Sedan's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body">If the throttle blades are 180's, that appears to be a Holley 9381 which is an 830 cfm carb. The annular boosters are a telltale sign. </div></div>
X2
Also, just like Day2 69Z asked......what numbers are stamped on top of the metering blocks?
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 07-30-2015, 03:53 AM
I will check my notes here at home and see if I wrote them down.. car is stored a few miles away.
Old 08-06-2015, 06:49 AM
Ok... looked again and front block looks like 8543 stamped and rear is 9108. Also looked at the top closer and see 9380 cast into the top of the main body. Didn't see that before. I didn't pull the carb to check the throttle blades.. just too damn hot to work until the last couple days..
Old 08-06-2015, 01:27 PM
Jeff -- looks to me you have a 4779 (750CFM) ... TAZ
