Old 07-16-2015, 08:44 PM
Default Early Muncie Decode
Hello,
My Muncie 4spd on my (in transit) 69 BB Camaro has the code P9P17. From what I have read the early 69 Muncie's did not have an A,B, or C after the code. The A,B,C are what designates if they are a M20, M21, or M22. So with that said, how can I can tell if its an M20 or M21?
I am ruling out M22 because of no drain plug of course.
Thanks for the help!
Anthony
Old 07-16-2015, 09:56 PM
John Brown's Avatar
Default Re: Early Muncie Decode
Number of rings (grooves) cut into the input shaft. No grooves is a M20, one groove would be a M21. Since you also bring up M22, M22's also have no grooves, but you've already ruled that out.
John Brown
Old 07-16-2015, 10:15 PM
bergy's Avatar
bergy bergy is offline
HMMMM - I'm used to 1969 Muncies. M22 = no grooves, M20 = 2 grooves
Old 07-16-2015, 11:00 PM
Learn something new every day.
Thanks guys!
Can't wait to receive the car so I can take a look.....
Old 07-16-2015, 11:55 PM
hiperf69 hiperf69 is offline
Yenko Advertising Member
M-20's are two grooves
M-21's are single groove
M-22 are No groove
UNLESS
you come across an aftermarket input .
These also came with No groove's.
Same with Clusters
Groove's coincide with Imput's
And the factory M-20 Cluster's come with the anti-Rattle plate
riveted to the front of the Cluster.
Joe
Old 07-19-2015, 06:11 PM
Fast67VelleN2O's Avatar
Some of the information above is correct.
1963-1965 Muncie M20 and M21 transmissions did not have any grooves either.
Day 2 is Life.
