Old 07-08-2015, 12:06 AM
ZiggyL78's Avatar
ZiggyL78 ZiggyL78 is offline
Default 12 Bolt ID Code
I just picked up a 12 bolt rear.Passenger tube says CDK0302B1.Passenger casting B180.Drivers casting 87890.There is also a casting # 00N20.It measures 62" outside drum to drum.Maybe 62 1/2".It's in my truck and raining right now.
From my research it's a 1970 A body with a 2:56 posi built in Buffalo NY.I was told it was out of a Monte Carlo.I can't see a posi tag.It's quite clean for original.Is it normal to have orange paint on the shock mounts?One brake drum is seized.What do you guys think it's worth?
Thanks
Real Canadian Rock
https://www.youtube.com/watch?v=Zdeo-i6uw5g
Old 07-08-2015, 04:01 AM
marxjunk marxjunk is offline
Default Re: 12 Bolt ID Code
extremely rare..not desirable....id think any 12 bolt drum to drum is 4 or 5 hundred..if the posi is in there..its a couple hundred..i think you can buy a thick gear...
Mark
