Old 06-23-2015, 07:37 PM
Default Original GM Holley 4 Barrel Carb List 4054 68-69 C
This is an original GM Holley 4 barrel carburetor for 68-early 69 Corvette 427/430HP L-88 engines only. . The numbers stamped on the choke tower are as follows: 3925519-AN List 4054 705. The Holley List 4054 was installed by GM on the following applications: 1968-early 69(first design) 427/430HP L-88 ONLY. The 705 is the date code which decodes as the fifth week of October, 1967. This is a true early production dated L88 carb.
This carb is in very good original condition as shown. There are no breaks, repairs, or modifications. The coloring is very nice as shown and all parts move freely. The carb is totally complete with the exception of the choke parts. Some say these carbs came with the choke parts installed but disabled. Others say they did not come with choke parts at all. Either way, if you need the choke parts, they are readily available from many sources. The front metering block is stamped 5247 and the rear is stamped 5253. This is simply a very nice original GM L-88 Holley carb with a production date code.
$4250
Thanks for the ad,
