Old 06-19-2015, 03:05 AM
Default Thermostat by dimensions
Working on one of my odd ball cars.
Replacing the water pump and some 50 year old hoses (just a little brittle).
Figured while I was into the cooling system, I would replace the t-stat.
The one I took out is a Delcostat 180 Degree, all brass. Mind you, it is still working fine, but I have NO IDEA how old it is.
It is just slightly larger than a 60's GM t'stat. The bas is right at 2.3125 inches, or 2 5/16. For you metric guys, it is just under 59mm.
I have looked with my limited interweb expertise (very limited... been told I am an internet tard), but can't find ANYWHERE that lists thermostats by dimensions. Other than the wider seating flange, it looks just like an old GM thermostat.
Any ideas?
Old 06-19-2015, 11:33 PM
Default Re: Thermostat by dimensions
I think I have this handled.
The NAPA store had a book of t-stats by dimensions, and an understanding and helpful employee. Gotta love the small town atmosphere here in Guthrie.
Although none were 2 5/16 (or 2.3125) there was one that showed to be a bit larger, but it had a built in "O" ring on it.
Application showed it was for a Cummins turbo diesel truck engine.
I removed the built in "O" ring and it is right at 2.3125.
Not sure why I am posting this, as hopefully there aren't any other knuckleheads on this site working on such an odd ball engine.
Old 06-20-2015, 05:36 PM
You never know, Lynn [img]<<GRAEMLIN_URL>>/smile.gif[/img]
