Old 05-27-2015, 01:39 PM
brent396's Avatar
brent396 brent396 is offline
Default L79 68 BLOCK
http://southjersey.craigslist.org/pts/5007471965.html
1968 ChevyII 396 375,1969 Camaro 396 375 survivor , 1969 Dynamotion Copo Camaro,1968 L 79 ChevyII ,1969 Camaro 427 ratsness ,1967 Chevelle L79
Old 05-27-2015, 02:32 PM
MailOrderMotion MailOrderMotion is offline
Default Re: L79 68 BLOCK
Not a bad deal at all.
Old 05-27-2015, 04:01 PM
Fast67VelleN2O's Avatar
I know the seller. Good dude. Right around the corner from me.
Day 2 is Life.
Old 05-27-2015, 05:00 PM
jasonL78 jasonL78 is offline
That's a smoking deal.....
Looking for the next project.
Old 05-27-2015, 05:17 PM
Day2_69Z Day2_69Z is offline
Wrong crank....
All Hi Perf. L79's Had a Steel Crank. Regardless of small journal or large journal.
The Engine is identical to a Corvette L79 sans the bolt ons......alt., dist , carb and ram horns.etc.
Old 05-27-2015, 05:47 PM
68l30's Avatar
68l30 68l30 is offline
IMHO 68's had a large journal cast crank..My 0702 L-30 has one and it is one of the last. In fact, some were not even drilled for a balancer bolt. Mine was not... I don't believe many of the 68's were "Steel" both L-30 and L-79...It's a very different animal from the 67's ...
BIG
Old 05-27-2015, 06:14 PM
300deluxeL79's Avatar
300deluxeL79 300deluxeL79 is offline
'68 L79s got a lrg journal steel crank #3914672
Old 05-27-2015, 06:21 PM
68l30's Avatar
Was that the norm? I know All the L-30's were cast.
Were there ever any Tonawanda L-79's, my L-30 was built there...
BIG
Old 05-27-2015, 06:26 PM
markjohnson's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 300deluxeL79</div><div class="ubbcode-body">'68 L79s got a lrg journal steel crank #3914672 </div></div>
^^^THIS^^^ . . . . and it's a hard crank to find if you need one.
Old 05-27-2015, 06:38 PM
'68 L79's Used Forged pop up /Domed 11:1 TRW/GM Pistons, therefore a Steel Crank, 8&quot; High Performance wide balancer with a drilled nose.
64 cc Heads, Hydraulic cam with Pressed in rocker studs
Passenger cars used the Log type exhaust manifolds , Corvettes the Ram manifolds.
If someone here buys this Engine I have an NOS GM Balancer for it. A 8&quot; spec-hiperf non finned balancer which is nearly identical to a '67-'68 302,
Will sell this for $300 shipped
