Old 05-16-2015, 12:03 AM
scott s scott s is offline
Default 1967 muncie trans question
I just picked up a nice proj and noticed my car was built 05C on the cowl tag and my muncie is stamped P7E24 iam thinking thats later than the build of the car right? But the vin is stamped on the top of the trans ,Its a cali car if that matters? Thanks.
Old 05-16-2015, 12:46 AM
luzl78 luzl78 is offline
Default Re: 1967 muncie trans question
That's may 24 on the trans. A month before the car build.
Old 05-16-2015, 01:37 AM
COPO COPO is offline
I think the date on the trans is fine. Just a few days before the car's build.
Old 05-16-2015, 02:27 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: COPO</div><div class="ubbcode-body">I think the date on the trans is fine. Just a few days before the car's build. </div></div>duh, 5c is May, not April. My bad.
Old 05-16-2015, 02:41 AM
Wouldn,t o5c build only add up to may 21st? if there are 7 days in a week?just seems very close.
Old 05-16-2015, 09:37 AM
iluv69s iluv69s is offline
I know some camaros had rears dated slightly after the car...probably same with your trans...good question for Kurt from CRG
Old 05-16-2015, 10:26 AM
69VN's Avatar
69VN 69VN is offline
That's unusual Scott that your trans is dated one week after your build date. I looked on line for the May 1967 calendar year and found out that May 1 was on a Monday...May 24 was on a Wednesday which is 3 weeks later. Very odd. By the way, Jerry M's book states that California built cars exclusively stamped their transmissions (4 spds anyway) on the top of transmission case.
Sal [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 05-16-2015, 10:54 AM
Car's build when TT was stamped could have been started at end of 3rd week of May and build continued into the 4th week of May. Unusual, but still think the trans is likely original to the car given the other evidence.
Old 05-16-2015, 11:43 AM
MosportGreen66's Avatar
I agree with Charlie. I bet its original. I looked at a '69 Z with the engine build date within 1 week from engine assembly date to the car's final assembly date. I found it so hard to believe only because the supply chains of the 1960s were hardly just in time or lean. Ironically the car had a beautiful stamp. Nonetheless the car proved to be 100% legitimate. Same applies here...
Old 05-16-2015, 01:14 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MosportGreen66</div><div class="ubbcode-body">I agree with Charlie. I bet its original. I looked at a '69 Z with the engine build date within 1 week from engine assembly date to the car's final assembly date. I found it so hard to believe only because the supply chains of the 1960s were hardly just in time or lean. Ironically the car had a beautiful stamp. Nonetheless the car proved to be 100% legitimate. Same applies here... </div></div>
I think there are documented blocks that are date assembly stamped the next day after casting date... ( if my memory serves me)...where is Kurt when you need him...haha..???
..and I had a 69 RS Z Van Nuys car that had a BB and M-20 when I bought it... I never realized it was the original trans. til I put a clutch in it and found the VIN on top of the muncie... I never thought they put M20s in the Z's until then either... !! Boy was I happy because that helped document the car as a real Z also !!
