Old 05-12-2015, 11:15 PM
69VN's Avatar
69VN 69VN is offline
Default Original Radiator Overflow Hose
An original 1969 Camaro radiator overflow hose. It has the three ribs and measures in at 21 1/2" long. It is 1/16" thick and has an inside diameter of 3/8" with and outside diameter of 1/2". Was talked about here last month in the Technical & Restoration section...link below.
https://www.yenko.net/ubbthreads/ubbt...ose#Post609698
$30 shipped to lower 48 states. PM me if you are interested.
Sal
