Old 05-09-2015, 08:26 PM
WorkinProgress WorkinProgress is offline
Default 1969 Camaro Curved Neck Radiator Auto Original
Complete curved neck radiator for a big block '69 Camaro with automatic. Used with 4.10, 4.56 gears or with low perf B/B with air conditioning.
Radiator appears to have been pulled from a Camaro decades ago in its original condition. Still retains its original core, tag, and the pass side B/B only radiator clip.
The radiator tag has one crack in the right side support that connects the tag to the tank. That will need to be soldered. There is a dent in side of tank below the curved neck that will need to be removed. The top support has a slight bend that will need to be straightened when recored. That is if you are going to reuse them.
Chris White (AKA on this site Ls6 Ragtop) has seen this radiator and if you want it restored in its original form you can contact him. I can deliver to him if needed.
Price is $2500.00
- Warren
