Old 04-24-2015, 04:38 PM
Edgemontvillage's Avatar
Edgemontvillage Edgemontvillage is offline
Default 1969 Camaro M-Leaf Shock Plates - LOCATED THANKS!
<span style="font-size: 14pt">Need a set of original multi leaf spring shock plates for a 1969 Camaro, including shock mounting posts (not shown) in good condition, please PM if you have a set. Thanks, Lloyd. </span>
(reference photo)
Old 04-24-2015, 10:54 PM
enio45 enio45 is offline
Default Re: 1969 Camaro Multi Leaf Shock Plates
lloyd,
- i have a few sets but that are slightly bowed......i believe they can be straighten with a press.....
so , if u find any avail, make sure they are not bent from over tightening...... or buy mine and put the press on them :-)
- the shock mounting post are part of the rear shocks assembly - not a separate part unless you get after market shocks then the posts are
separate.
replacement spirals for the rear have the post part of the shock....as originals...
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 04-25-2015, 12:07 AM
bolt them up Fast Eddie and you will never see any bows.
Original parts are the best!
Old 04-25-2015, 02:22 PM
Thanks Eddie, I am awaiting photos on a set from a SYC Member; hopefully that set is straight.
Lloyd.
