Old 04-19-2015, 11:20 PM
69VN's Avatar
69VN 69VN is offline
Default Radiator Overflow Hose
Could anyone verify by looking closely at these photos and see if this is an original radiator overflow hose? Was removed from an OG coded radiator years ago but uncertain if it's real or repop. It does have three ribs along the entire length. Measures in at 21 1/2" long. It is 1/16" thick and has an inside diameter of 3/8" with and outside diameter of 1/2". Is there is anything else I should be looking for on the hose?
Sal
Old 04-19-2015, 11:25 PM
Default Re: Radiator Overflow Hose
Aside from the 3 ribs,do you feel a seam 180° from them?
Old 04-19-2015, 11:29 PM
69VN's Avatar
No Rick I don't feel a seem 180* from the 3 ribs. Is that good news or bad? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 04-20-2015, 03:09 PM
That's Good,I would say yours is an authentic original.
I've only seen repro with a raised 4th 180° seam so far.
Old 04-20-2015, 10:32 PM
69VN's Avatar
Thanks a lot Rick! [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Sal
Old 05-12-2015, 02:13 PM
miket1 miket1 is offline
Sal, this is the same the hose on my 69Z, 3 ribs.
69 Z28 Burgandy
Old 05-13-2015, 12:02 AM
69VN's Avatar
Sent you an email Mike.
