Old 04-19-2015, 11:22 AM
69VN's Avatar
69VN 69VN is offline
Default Original 12 Bolt Rear Brake Hose, Bracket, Brass T
Can anyone identify what I have here? I got an original 12 bolt rear brake hose, bracket & brass T. Question: Is the mounting bracket pictured the correct one for the brass T fitting? I understand there were a few different mounting brackets for 1st. gen cars. It was removed from a '69 12 bolt rearend. See pics below.
Sal [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
