Old 04-17-2015, 09:48 PM
Default AC Hand Tachometer
AC Hand Tachometer HT1, new in slightly weathered box. 0-4000 PRM range and dated 6-55. This little tool enables you to get a somewhat accurate RPM reading by simply putting the rubber tip on a fan belt or anything you can reach that is spinning. Can be put on the outside of a rotating surface or with the pointed tip can be inserted in the center of a rotating shaft. Nice tool to display in your showcase or on the shelf. Comes as originally packaged with directions, extra tips, extension rod and original case. $100 shipped anywhere in the lower 48.
Old 04-17-2015, 09:58 PM
MailOrderMotion MailOrderMotion is offline
Default Re: AC Hand Tachometer
PM sent
Old 04-17-2015, 10:00 PM
Sold pending payment.
Old 04-21-2015, 02:36 PM
Payment received. Thanks Dave and sYc.
