Old 03-07-2015, 12:47 AM
69VN's Avatar
69VN 69VN is offline
Default 1955 Buick 264 Nailhead
*Posting this for a friend! 1955 Buick 264 Nailhead engine. Bored .30 over. Engine was never fired up. Everything inside the engine is new. Included is an Offenhauser intake 3x2 Rochester carbs with linkage, distributor, valve covers & breather cap, fuel pump, water neck, water pump pulley, exhaust manifolds. Everything you see on that engine comes with it. $3000.00 or best offer. Ask for Slim @ Academy Automotive. Shop phone number 215-464-2440.
