Old 02-09-2015, 10:10 PM
iluv69s iluv69s is offline
Default 60 vette motor and trans id/value?
recentky saw this motor and trans that was pulled from a running corvette that is being converted to make a street rod.
block cast number 3859532 cast date is C59...looks like CE on the pad alond w other numbers(hard to see)... did they make CE's back then? also has cast intake 3746829 dated j (or i) 9 9 and original looking carb, power pack heads, correct exhaust,generator brackets, engine mount,etc.
trans has 11 23 59 on tail ...and T10-1B W.G.DIV. and looks like A (or 4)-12 below ....has hurst shifter body.. is that correct? looks like correct pull up handle, etc? looks like oroginal stlye bell housing also...did they put VINs somewhere on the trans?
this car ran and drove real nice when engine/trans recently pulled.
any ideas on ID, value? thanks SYC
