Old 02-02-2015, 03:17 AM
ALLZS ALLZS is offline
Default DRIVESHAFT STRIPE COLORS
LOOKING FOR THE CORRECT COLOR COMBO & PLACEMENT FOR A 69 L78 4 SPEED NOVA WAS THE L78 CAMARO THE SAME ?
Old 02-03-2015, 05:46 PM
SeattleCarGuy SeattleCarGuy is offline
Default Re: DRIVESHAFT STRIPE COLORS
These pics are from a 24,000 mile original '69 L78 M40 Nova. Sorry, don't have a 4 speed and don't know the different color pattern for 4 speed.
Paul
'62 Bel Air 409/409
'63 Impala SS 409/340 convertible
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Old 02-05-2015, 01:28 AM
resto4u resto4u is offline
I think the original stripes are crayon, not paint.
Old 02-05-2015, 02:20 PM
camaromb camaromb is offline
They were paint I believe, you can usually see the brush lines. I had an original LS6 driveshaft that had paint from the stripes running front to back from what looked like lying on a table after striping.
Old 02-05-2015, 02:31 PM
I second the paint theory. At least on the Chevelles I usually mess with.
Chris
Old 02-05-2015, 03:15 PM
Nova's are paint as well. I only know the Deuce stripes, yellow-green-yellow, and I don't think they would be the same for an L78 car.
Old 02-05-2015, 03:45 PM
Furback Furback is offline
The driveshaft out of the 68 Nova parts car I just junked. Green - Brown - Orange stripes about 12" from slip yoke end. Car was 307 Powerglide car.
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1964 Ford short step
1929 Ford Coupe
1931 Ford Coupe
1986 GMC Wrangler 4X4
Old 02-06-2015, 01:14 PM
Keith Seymore's Avatar
Likely not the same between Nova and Camaro.
The paint stripes were a form of visual identification (like an assembly plant "broadcast code" or "pick code&quot and would be different for each unique part number.
Anything that would create a new proliferation of part (ie, tube diameter, material thickness, tube length, slip yoke size/type or u joint size) would drive a new part number and therefore unique stripe pattern for that drive shaft part/vehicle powertrain combination.
And - yes - they were paint. Brushed immediately after the balance operation (while still in the balancing fixture). They were not taped in order to have clean edges. Pretty sloppily done, actually.
K
'63 LeMans Convertible
'63 Grand Prix
