Old 01-27-2015, 05:52 PM
rts rts is offline
Default 65 chevelle fan clutch
Does a 1965 chevelle 327/250hp engine come with a fan clutch or a fixed blade fan?
Also does that configuration come with or with out a schroud?
Thanks
Old 03-11-2015, 02:06 AM
Default Re: 65 chevelle fan clutch
If the car does not have Air conditioning, then a fixed blade fan was standard. A clutch fan could be ordered under RPO K02. The clutch fan was included with the air conditioning option.
If the car does not have air conditioning, then there was not a fan shroud with the standard radiator. If the car was ordered with the heavy duty cooling option RPO V02, then you got a fan shroud. If the car was ordered with air conditioning, then the HD radiator and shroud was included as part of the a/c option.
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
