Old 01-27-2015, 02:18 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Default Z28 firewall I.D.
Is there anything in this arrangement of holes (speedo cable?) and protrusion of emergency brake cable that identifies this car as a '69 Z28?
Old 01-27-2015, 03:05 PM
enio45 enio45 is offline
Default Re: Z28 firewall I.D.
not that i can see - -
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 01-27-2015, 04:52 PM
L78steve L78steve is offline
No hole for ZL2.
Old 01-27-2015, 05:19 PM
robber6910 robber6910 is offline
did the flat hood cars have the ZL2 hole on the fire? If he pulled the back seat wouldn't the "X" designation be on the rear seat frame?
Old 01-27-2015, 08:13 PM
Tracker1's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: robber6910</div><div class="ubbcode-body">did the flat hood cars have the ZL2 hole on the fire? If he pulled the back seat wouldn't the &quot;X&quot; designation be on the rear seat frame? </div></div>
Los Angeles car, no X-codes.
I ain't nobody, dork.
Old 01-27-2015, 09:38 PM
Tracker1's Avatar
I thought there was something in the positioning of the gas pedal exit in relation to the steering column holes. But I figured out thanks to CRG - you can I.D. a Muncie car, but not specifically a Z.
CAR OF INTEREST:
Old 01-28-2015, 12:53 AM
Zman1969 Zman1969 is offline
engine mount #s Z/s and SS350?? use same engine stand but not other SBCS also check length if pitman arm the Z's got fast ratio should be 5.8&quot; long for fast ratio
from David Pozzis site:
POWER LONG 5.8&quot;, 3953237
POWER SHORT 5.25&quot;, 3935711
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 01-28-2015, 01:14 AM
No hole for flat hood Z's.
Old 01-29-2015, 05:37 PM
cook_dw's Avatar
cook_dw cook_dw is offline
The single 3/8&quot; fuel line, Muncie speedo hole are good signs but not 100% proof.
Old 01-30-2015, 11:47 AM
68ys8030 68ys8030 is offline
the firewall on my 69 Z28. It has a late build of November of 69. See the hole above the fuse box hole for the ZL2 ducted hood and the hole below the fuse box hole for the factory tach. Both are stamped holes and not drilled holes. My car has no console or console gauges. I hope this helps!
63 split window fuelie
69 z28
financing my 2 sons cars.... 67 fastback mustang and 69 Camaro.
