Old 01-26-2015, 12:53 AM
wisemanz28 wisemanz28 is offline
Default Restoration of YH rims
I'm restoring some YH rims and have a concern about the area where the sides of the tire meet the edge's of the steel rim. The area is pitted and I'm not sure if this will seal properly. If rims are pitted can't tire shops use a sealer for just this situation ?
Old 01-26-2015, 10:46 AM
69 Post Sedan's Avatar
Default Re: Restoration of YH rims
I just had a pair of tires put on a some Cragar wheels and one had some light pits. He told me that he will lay the sealer on thick then wipe it off afterwards.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 01-26-2015, 01:49 PM
Zman1969 Zman1969 is offline
well the tire seals on the 15" bead diameter area, the outer lip isnt a sealing area. I may suggest some epoxy steel to smoth that area out should stick fine on a freshly blasted area then file/sand down and paint it
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 01-28-2015, 02:07 AM
resto4u resto4u is offline
you can sand blast them, then use duraglass or could lead them.
Old 01-28-2015, 02:43 AM
BLACKLS5 BLACKLS5 is offline
I've used 3-M dura-mix panel bonding adhesive with good results. I just used a bondo spreader and spread it as evenly as possible on the pitted area. It actually flows out a bit to a smooth finish and gets hard as a rock. I didn't even sand it down afterward.
Old 01-28-2015, 11:02 PM
I took the rims to the local tire shop and to my surprise they didn't see an issue, they did mention that they had a product that they will apply to help with the sealing. Thanks for all the suggestions.
