Old 01-01-2015, 01:59 PM
69L78's Avatar
69L78 69L78 is offline
Default Plastic Headlight Restoration
Do any of the headlight restoration products really work for more than a couple months?
Old 01-01-2015, 02:11 PM
chevyman0429's Avatar
Default Re: Plastic Headlight Restoration
I was told the Miskito spray called OFF or REPeLLANT was twice as good and last a lot longer. I haven't tried it yet myself. Spray on and wipe off
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Old 01-01-2015, 03:00 PM
OldZ28Owner OldZ28Owner is offline
I ordered and used a kit from Griot's Garage that is still looking great. It involves sanding the lenses and then spraying on a clear spray, which hardens in sunlight (UV). When I got the lenses all sanded, my first thought was "Oh, crap, I've just screwed up my headlights!" Don't worry - the spray goes on smoothly and all of the sanding marks go away. It does take using 400, 1000 and 2000 grit paper, though. Take your time - still looks good after two years!!!
Old 01-01-2015, 03:41 PM
69L78's Avatar
Thanks, I was looking at the Griot's Garage product. The kit only comes with the 600 grit.
Old 02-03-2015, 01:36 PM
firstgenaddict's Avatar
The UV activated clear must be the ticket.
My lenses in my Grand Cherokee were yellowed and scratched. I used flexible rubber block and 600-2000 then 3000 trizac followed by plastic lens polish, when done they were crystal clear and looked great, after a year they are beginning to haze again.
I DID NOT USE ANY type of sealer or clear coat.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
