Old 12-22-2014, 01:15 AM
enio45 enio45 is offline
Default speakers 4x10 and 6x9's - need some
need 2 - 4x10's and 1 - 6x9 single wire rear speaker.
both are for 69Z cars - where are you guys buying these?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 12-22-2014, 07:05 AM
69VN's Avatar
69VN 69VN is offline
Default Re: speakers 4x10 and 6x9's - need some
Eddie are you looking for aftermarket or GM speakers?
Sal
Old 12-22-2014, 07:28 AM
Woj's Avatar
Woj Woj is offline
Eddie,
You might want to check with Jackson Speaker Service. He might have what you are looking for. If not, one of those classic car junk yards in Phoenix might, and you can then rebuild it. I've had Jackson rebuild numerous original speakers and the quality of work is excellent. If you hit the junk yards, try to get the little grounding clip that goes with the speaker (for the rear single wire speaker).
Here's someone who sells a pretty decent repop.
http://www.turnswitch.com/speakers.htm
I'll check to see if I have any single wire 6 X 9's.
Phil Woj
Old 12-22-2014, 02:41 PM
Thanks Sal and Woj!
I would like the front to be GM as it has the special front mounting bracket that fits onto the holder. I have several later 4x10's made by delco as later style that are round, but i don't want to modify the bracket.....so looking for orig ones redone.
On the 6x9, the car has the rear fader switch on the am radio tune knob.....so the rear speaker wire is a single connector as WOJ states - so, this does not have to be GM but equivalent. Question for the rear - i assume that us a 10 Ohm as well?? Did not think about this until now??
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 12-22-2014, 03:08 PM
Woj's Avatar
Woj Woj is offline
Eddie,
Yes, these are 10 ohm speakers. I have a core front speaker without wire if interested.
Phil Woj.
Old 12-22-2014, 06:38 PM
bigjake's Avatar
bigjake bigjake is offline
Eddie---I have a 4 X 10 front speaker and bracket. I tried to upload pictures but it won't let me. Interested?
Old 12-22-2014, 08:53 PM
69VN's Avatar
I found a much later set of (Delco Electronics)6x9 rear speakers. I do not know if they are 10 ohms but I don't think you can use them because they have two copper leads going into one plug on the end. If you'd like for me to post some pics later just let me know.
Sal
Old 12-28-2014, 03:48 PM
woj and guys, i think i have s=for thrones i needed from another member - they have been restored by jackson speaker service as well. Appreciate the advise and the offers.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
