Old 12-21-2014, 02:56 PM
69VN's Avatar
69VN 69VN is offline
Default NOS Ford Autolite Regulator #C3TZ-10505-B
I don't have much info on this but it is an NOS Ford Autolite regulator part# C3TZ-10505-B. Opened for the first time since being packaged decades ago. The actual part number on the regulator itself reads C2AF-10505-A. It is a 15 volt 30 amp. regulator. Was informed by some members here that Ford would supersede part numbers all the time. It dates back to the early 1960's and may be used on some full sized Fords as well as trucks and Mustangs. But I leave it to the Ford experts out there to do your homework if you maybe interested in this part.
$100 shipped to your door as long as you are within the 48 lower states. PM me with any questions. Thanks.
Sal
