Old 12-19-2014, 07:19 PM
300deluxe 300deluxe is offline
Default H70-15 Wide Oval tire question
I have a 1969 Lemans with 15"x7" Rally two's. Wondering about tires for these wheels. I want Wide Ovals on my car. A guy on Craigslist has a set of four H70-15 that have less than 200 miles, near new for $200. Would they look good all the way around or just on the rear, then get F or G 70's for front. Any comments, and pics of cars with H70's in rear. Please help, thanks, Troy
Old 12-19-2014, 07:36 PM
GTO_DON GTO_DON is offline
Default Re: H70-15 Wide Oval tire question
Those tires are really too big for that car. Especially on the front.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 12-19-2014, 10:01 PM
67 Nova Boy's Avatar
X2...F-70 in front will be perfect for that car.
Dave
67 Nova Boy
Old 12-20-2014, 11:32 AM
H's on the front..................a steam roller!
E or F's up front!
Old 12-20-2014, 12:32 PM
Listen to Sammy and Donny they are the resident old school kings...the only difference between them is that Sammy is a little older [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
Old 12-20-2014, 08:07 PM
x77-69z28's Avatar
H is the height. 70 is the width. You can run H-70's all around, especially if you can get a set for $200! I would jump on them
Old 12-20-2014, 08:20 PM
I hope you ate your Wheaties or have power steering!
Old 12-20-2014, 10:17 PM
Day2_69Z Day2_69Z is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">I hope you ate your Wheaties or have power steering!</div></div>
I have manual quick ratio steering in a
SB with F60 15's on 7&quot; wheels which I'm sure you saw,,,,,not to bad to steer parking or low speed tight turning ?
Your thoughts Sam.
Old 12-20-2014, 11:39 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: x77-69z28</div><div class="ubbcode-body">H is the height. 70 is the width. You can run H-70's all around, especially if you can get a set for $200! I would jump on them </div></div>
Vice versa-- Letters were replaced by mm for width and the 60/70 are the side profile (percentage of the tread coverage of the sidewall).
L60 and F60-15 are a great big and little combo for a rake. L60 and F70-15's are close to level. G60-15 aqnd E60-15 are the tire setup used on the AAR 'Cuda and the T/A Challenger.
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 12-20-2014, 11:59 PM
L60 and F60-15 are a great big and little combo for a rake. L60 and F70-15's are close to level. G60-15 aqnd E60-15 are the tire setup used on the AAR 'Cuda and the T/A Challenger.[/quote]
Cool....and perfect look on my 69 especially with D80.....
I'm running L60 &amp; F 60 's Goodyear Polyglas ..... [img]<<GRAEMLIN_URL>>/cool.gif[/img]
