Old 12-07-2014, 10:51 PM
ALLZS ALLZS is offline
Default MISC PARTS 69-73
2 - 69 SMALL BLOCK AALT BRACKET WITH ALL ORIGINAL BOLTS $80.00 EACH PLUS SHIPING 1 - 73 SMALL BLOCK ALT BRACKET WITH ALL THE ORIGINAL BOLTS $45.00 PLUS SHIPING 1969 SMALL BLOCK FUEL PUMP PLATE ROD AND ORIGINAL BOLTS $55.00 PLUS SHIPING DIST HOLD DOWN WITH ORIGINAL BOLT $18.00 YOU PICK PLUS SHIPING TRANSMISSION MOUNT BOLTS WITH THICK WASHER MARKED "C" $50.00 PER SET PLUS SHIPING 69 CRANK PULLEY BOLT SET $45.00 PLUS SHIPING BIG BLOCK FUEL PUMP BOLTS $40.00 PLUS SHIPING ORIGINAL A/C CAPS $25.00 PLUS SHIPING
