Old 11-09-2014, 07:39 PM
luzl78 luzl78 is offline
Default Rear end date
When would a rear be stamped with a 67 Norwood camaro built at the 1st week in june
Old 11-09-2014, 07:49 PM
69VN's Avatar
69VN 69VN is offline
Default Re: Rear end date
From my understanding it may have been up to 3 months prior to the build date of your Camaro. If I'm wrong on this feel free to chime in. This may or may not help...but check out the website...
http://camaros.org/drivetrain.shtml#axle
Sal
Old 11-09-2014, 07:57 PM
When the car was ordered for build did they just have rows of rears stacked up with the code for the ratio and just pull it off the rack or was the rear stamped for each particular car?
