Old 09-18-2014, 08:33 PM
wisemanz28 wisemanz28 is offline
Default 1969 camaro Z28 backfiring
What would cause my 69 Camaro Z28 to backfire? First time it happened when I was starting the car and today it happened when I was accelerating on the highway. The car is backfiring thru the exhaust
Old 09-18-2014, 09:08 PM
69VN's Avatar
69VN 69VN is offline
Default Re: 1969 camaro Z28 backfiring
*Source Wikipedia: Exhaust system backfires occur in engines that have an emission system malfunction, like an air injection system diverter valve problem, or an exhaust leak. In some high-performance vehicles, when a driver shifts up and lets off the accelerator, the engine has a moment of running rich. This causes an incomplete burn which causes the fumes to explode in the exhaust system along with an audible pop or bang sound. This is a result of working equipment, and is unlikely to cause damage. Also, poor or unregulated engine timing is often a cause of intake backfires, but can also be responsible for exhaust backfires. Improper wiring in the ignition can also lead to timing issues and backfires. Low fuel pressure, clogged fuel filters, and weak fuel pumps could cause a severe lean air-to-fuel ratio during fuel injection. Hope this helps.
Sal [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-18-2014, 09:28 PM
Dicky's Avatar
Dicky Dicky is offline
I was taught that &quot;After fire&quot; was out the exhaust and
&quot;Back fire&quot; was out the intake...
Just a nomenclature FYI
If it is consistent could be ign. timing. [img]<<GRAEMLIN_URL>>/dunno.gif[/img] [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
DH [img]<<GRAEMLIN_URL>>/flag.gif[/img]
Dicky
Old 09-18-2014, 11:30 PM
m22mike's Avatar
m22mike m22mike is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Dicky</div><div class="ubbcode-body">I was taught that &quot;After fire&quot; was out the exhaust and
DH [img]<<GRAEMLIN_URL>>/flag.gif[/img] </div></div>
Thank you, The way I learned it too.... [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Old 09-18-2014, 11:31 PM
napa68's Avatar
napa68 napa68 is online now
Sounds like the points and or condenser may have s#it the bed if it came out of nowhere.
Old 09-19-2014, 08:16 PM
The car also backfired last week when I started it.
Old 09-19-2014, 08:29 PM
PeteLeathersac's Avatar
A few more thoughts;
Bad fuel, failing coil, intake leak?
Good luck!
~ Pete
Old 09-19-2014, 08:44 PM
Plowman's Avatar
Plowman Plowman is offline
One or more bad or open spark plug wire,sound's like one bad plug wire for now.
Old 09-22-2014, 12:58 AM
Hope you don't have a worn camshaft...
Old 09-22-2014, 03:12 AM
firstgenaddict's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr.Nickey Nova</div><div class="ubbcode-body">Hope you don't have a worn camshaft... </div></div>
X2
I assume it is a flat tappet cam, how many miles does the cam have on it?
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
