Old 09-01-2014, 02:28 AM
all_about_cars's Avatar
all_about_cars all_about_cars is offline
Default 69 350 engine
69 350 300 hp long block. This is a 3932386 block cast date I 14 8 that has been fully machined including cleaned bored decked and line bored. Heads are 041 dated I 10 8 fully machined cc'd machined for screw in studs and guide plates and fitted with new seats and stainless valves 2.02 and 1.60. Crank is dated I 16 8 has been ground .010 mains and rods. Rods are floating pin fitted with wiseco forged pistons that yield 9.6 to1 compression with the head gaskets I have with it. Rotating assembly has been balanced and comes with main and rod bearings, ring set that has been file fit to cylinders. Also has new guide plates, melling oil pump and screen and roller tip rockers. Cylinder bore is .030. I was building this for a 69 that has been sold. There was no expense spared on this and is being sold for less than I have invested. This is all fresh and ready for assembly after you pick a camshaft, lifters and timing chain. Call Eddie for any questions thanks 502 -291-7076 2500.00
