Old 08-06-2014, 04:18 PM
sheitman's Avatar
sheitman sheitman is offline
Default 1961 Chevrolet Corvette Convertible
1961 Chevrolet Corvette Convertible! 63,900.00
Serial Number: 10867S102014
Build Date 25 Oct 1960
Motor- Block#3756519 Casting Date I290(Sept 29 1960) Engine Code F1004C0. Engine rebuilt at mile 91014 Correct but not matching.
Heads- 3774692 (Also F-28-016-18-0?)
Transmission-Warner 4-Speed: Front case -T10-1B W.G. DIV Q2 J-28-0 (September 28, 1960, no “I” used in these castings)/ Extended Housing Casting# T10-7B 9-28-60.
Bellhousing- Casting Number #3779553(verified correct).
Radiator- 3151116
Expansion Tank- 3151016 Code 6 J. Note:1960 Calender year supply tanks have "6"(rather than "60&quot for the year designation. Radiator Cap #861306 (#306 pressure 13lbs- Correct).
Manifold- Aluminum 3739653 Dated 2-18-59(splash shield installed).
Carburetors- 3785554 WCFB3182S (front); 3744004 WCFB2614S (rear) Casting # for man body/air horn 0-049/6-1299. Professionally Restored by Bob Kuntz(2007).
Water Pump- 3782609
Water Pump Pulley- Stamped 3724816(Correct)
Crankshaft Pully- Stamped 3756328(Correct)
Fuel Pump - #4656 Die Stamped "AC"(Restored- correct)
Exhaust Manifold- Left 3749965(D25) Right #3750556(D8)
Generator-1102043 0J2 (1960/Sept/2nd) Restored by Bob Reams August 2008.
Horn Relay- 1116781 Stamped("781”)("12VN”).
Starter-1107889 0J28 1960/Sept/28
Distributor- 1110891 #0K10(Oct 10, 1960) The letter "I" was not used to represent the month of September.
Master Cylinder- Casting Number 5456022 Casting Date 71660 (Jul 16 1960).
Voltage Regulator- 1119001D(Apr 1960) 30 Amps(Correct) Professionally Restored by John Pirkle in Sept 2007.
Antenna Ward -173; Main Section 13”, 7 ¾” when pushed in. Middle section 18 ½”, upper section 19” to top of the ball on mast.
Soft Top- New. Put on by Ron's Corvette in Mass (Aug 2007)
http://www.dallasmotorsports.com/web...exas/14997945/
Contact Spencer Heitman for more information at 214-773-0588 CALL/TEXT
[email protected]
