Old 07-08-2014, 12:22 AM
VintageMusclecar's Avatar
Default L-88 air cleaner base
Does anyone offer a reproduction L-88 base that will clear the secondary accelerator pump lever on a double pumper Holley?
Thanks.
Old 07-09-2014, 04:05 AM
Default Re: L-88 air cleaner base
Anyone??? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 07-09-2014, 05:24 AM
Guest
Posts: n/a
Hammer and a socket to make room for clearance. The ones I've had (even those claiming to be L88 bases) needed massaging.
And btw...it is possible to do a pretty nice job.....if you're careful. [img]<<GRAEMLIN_URL>>/wink.gif[/img]
Wayne
Old 07-09-2014, 02:38 PM
Thank you Wayne.
Old 07-09-2014, 03:34 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
the original GM piece put on my car in 1972 has no base-to-valve cover tube so it wasn't an issue....
the re-pop (cuz I wanted the tube) has 'ever-so-slight' contact as seen by the mark here on the tube. I will have to give the tube a few hammer knocks to clear...
I ain't nobody, dork.
Old 07-09-2014, 06:32 PM
Tracker1;
Excellent pics, thanks.
Your carb appears to have a 30 c.c. pump on the rear, the 850 I'm using has a 50 c.c. pump which utilizes a significantly larger accelerator pump lever &amp; spring assembly. Short of mangling it, I'm not sure I'm going to get the base to fit at all.
Old 07-10-2014, 07:50 PM
Guest
Posts: n/a
With a REO kit, I'd be tempted to get a base from a Moroso 14-inch air cleaner and paint it black. They don't have the tube and they're close to the same drop as the OEM Chevy. Fit the Chevy top on it, use a push in breather on the valve cover and you're done [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Wayne
Old 07-10-2014, 09:01 PM
Wayne;
That's the basic design I just tried and it cost ~15 HP and 10 lb.ft.
Here's what I'm looking at now: http://www.r2cperformance.com/
Old 07-11-2014, 03:51 AM
Guest
Posts: n/a
That does look promising. Can you keep me in the loop if you dyno test it?
Wayne
Old 07-11-2014, 04:23 AM
Unfortunately I won't be able to get one here in time for the next round of testing on my 496 next week. However, I do want to pick one up and test it whenever it's feasible, and I do have another project coming up that will be more than suitable to do so. I'll cover that one in a new thread in my forum once I get it on the dyno.
