Old 05-30-2014, 09:31 PM
turbojet427 turbojet427 is offline
Default 67-69 Camaro NOS and Rare Parts
All parts are NOS or excellent original parts.
68 Camaro RS NOS in box tail light lens- $50
69 Z/28 140 "Off Road" Cross Ram Camshaft NOS in original tube- $375
66-67 Very early take off Disc Brake Rallye Wheel centers. Excellent take off a 67 Z/28 two weeks after the car was new.- $400
68-69 Z/28 NOS Drag Link. Part# 3958493- $100
68 Camaro original speedometer. 12,720 original miles- $50
69 Camaro Jack Base- $50
69 Z/28 Deep Double Groove crank pulley. Part# 3956668CG- $300
69-70 Solid lifter BB or SB NOS power steering pulley. Part# 3941105DD- $425
69 L78/L72 4346 Carb. Good driver or needs restored. Dated 974, 5583 and 4519 metering blocks, Throttle plates 172 and 173. Correct base plate with small crack on the bottom.- $375
67-69 Open element air cleaner assembly. NOS in box with chrome lid and 212 filter. Part# 6423907- $575
69 Camaro auto reverse lockout. Very good condition. QTY. 2- $50 each
293 BR Coil. Excellent original condition- $60
67-69 Camaro rear window trim. NOS in GM wrapper. Complete rear window set- $500.
Very LOW Mile complete L78 CE short block. 854 block, 6223 crank, dimple rods, original pistons & rings, oil pump, cam, timing chain. CE code. The short block is disassembled. Standard bore.- $3,000
#291 matched set of complete heads. Dated A 23 70.- $1,000
PM or call 814-244-7108. Pictures: http://www.motorheadcentral.com/profiles/3
