Old 05-29-2014, 04:11 AM
Enoch Enoch is offline
Banned
Default 63-74 Corvette Ft Suspension Hardware NICE!!!
EXTREAMLY NICE PIT FREE UNRESTORED FRONT SUSPENSION HARDWARE FOR 63-74 Corvettes.
1.Lower Control arm front TR bolts Knurled x-tra thick lock washers and N stamped nut plates You wont find nicer unrestored original!!!! Correct for 63-72 2 sets of 4 bolts/2 plates 120.00 per set
2. Lower control arm rear mounting hardware WB headmaking bolts with serrated washers and early style Lock nuts with dimples. Correct for mid 66-74 As nice as you will find 2 sets (2 bolts, nuts and washers) 80 per set
3. Steering box bolts RBW carriage bolts lock washers and nuts 3 sets (3 per set) 60 per set correct for 63-74
4. Idler arm hardware. 1 upper RBW hex bolt and early style dimpled nut, 1 RBW lower Carriage Bolt and early style lock nut. Correct for 63-74 2 sets (1 upper and 1 lower bolt per set) 60 per set.
5. Front Spindle upper bolts M headmarking correct for 63-74 again as nice as you will find. 4 sets (2 per set) 60 per set.
