Old 05-25-2014, 11:01 PM
bergy's Avatar
bergy bergy is offline
Default 12 bolt spring perches
Anybody out there in SYC land have a set of GM 12 bolt spring perches that they wouldn't mind parting with? Thanks!
Old 05-26-2014, 02:13 AM
marxjunk marxjunk is offline
Default Re: 12 bolt spring perches
the actual perches or the bottom plates?
i have plates
Mark
Old 05-26-2014, 10:29 AM
bergy's Avatar
Thanks for the reply Mark - somebody modified the actual perches on this rear - good used ones will also work if anybody has some.
Old 05-26-2014, 11:23 AM
iluv69s iluv69s is offline
I bought some from GM years ago..have you checked if they are still available?
Old 05-26-2014, 03:13 PM
ahh i see
i may have a connection for a used set if you want to go that way
Mark
Old 05-26-2014, 03:21 PM
jerry67 jerry67 is offline
New ones are available here http://www.moserengineering.com/susp...-brackets.html
Old 05-26-2014, 04:47 PM
bergy's Avatar
Thanks Jerry - the re-pro ones aren't quite correct. I'll check with GM tomorrow (didn't even consider that they may still be on the shelf). Anyone who is willing to part with a set of nice used - please PM or email me.
Old 05-26-2014, 04:56 PM
enio45 enio45 is offline
FWIW, I had a BE rear that had the perches modified. The guy I bought it from had the repo perches installed and when I got the rear it was determined that the perches were not put on correctly. The perches are to have a slight angle to them so the leaf springs will fit properly when installed to the frame. This is very key, and of course they need to be :clocked: properly as well.
Long story short, the rear was brought to Moser in Indiana, and they replaced the perches, ensured proper alignment, installed new bearing and made everything right. Great service!!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 05-28-2014, 01:15 AM
bergy's Avatar
Thanks for the info Eddie - my original perches are not cut all the way off - just modified. So I have the proper orientation still in place (hopefully). I've got a RH perch coming - still need LH - anybody? I'll take a set if need be. NOS or good used is OK.
Old 05-28-2014, 02:01 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: enio45</div><div class="ubbcode-body">FWIW, I had a BE rear that had the perches modified. The guy I bought it from had the repo perches installed and when I got the rear it was determined that the perches were not put on correctly. The perches are to have a slight angle to them so the leaf springs will fit properly when installed to the frame. This is very key, and of course they need to be :clocked: properly as well.
Long story short, the rear was brought to Moser in Indiana, and they replaced the perches, ensured proper alignment, installed new bearing and made everything right. Great service!! </div></div>
I believe 2 degrees angled &quot;in&quot; at the front of each perch.
I am sure someone can confirm.
