Old 05-20-2014, 07:26 PM
Day2_69Z Day2_69Z is offline
Default 69 Z/28 SURVIVOR TAKE OFF #668 #021 #403 #527
ORIGINAL GM 69 Z/28 TAKE OFFS FROM SURVIVOR DZ 302.... Some 67-68 look at complete ad.....
#668 Crank Pulley Deep Groove/double. Run out is Straight & True. Pitting inside and All #'s Visable. Was dipped/de-rusted painted black. Good Pulley just not show or NOS....$275 shipped USPS.
#021 May, E 69 dated Flywheel in Excellent bolt on Condition. W/ bolts. $150 (have V.G. Clutch & Pressure Plate For $25 if you pay the Shipping.
#403 Bell housing with original skin, No Cracks,Dings or Gouges, clutch fork,Very nice Boot & Bolts. $150
Correct Assembly line 69 Z28 SS V8 1 hole Alternator Brackets (3 pieces: Top,Bottom & rear 'V' support) $100.
#527 Drivers side 'LEFT' Exhaust Manifold (E 22 9 May Date) $400 + shipping USPS.
SOLD*** N.O.S. GM Rocker Spears 67-69 In GM Blue Plastic w/mounting flanges & screws. $300 + $38 Tube shipped USPS.
N.O.S. 67-69 F body GM Inner Door Fuzzies in GM Blue Plastic wrappers. (3 pieces...2 doors 1 quarter) $150
N.O.S. 1967-68 302 Z/28-327 Special Hi-Performance 8 Inch Harmonic Balancer #7173 MINT N.O.S. GM piece. $350
This will work on a 69 & up IF you Adjust the Timing mark 10 degrees off the Key way.
Small Block 8 inch Timing Cover, welded on tab for 69 & Up 302 327 350 etc. $140 shipped USPS.
69 Camaro Manual Trans Shifter bezel for console.Survivor Piece (GM) in Very Nice condition (no woodgrain) $60
69 Fuel/license plate door. Original GM Very Clean. This is the Correct door for 69 only. $100
69 GM Original/N.O.S. Washer Bottle & Hose. Heavy Plastic unlike the repros...Excellent. $50 shipped USPS.
67-68 Muncie Shifter Body F body Camaro Survivor used. 'T' stamped handle. pitted lower half, driver/survivor quality.... I may have the Linkage and brackets???? $150 for shifter only.
1111168 67 Camaro SS350 Pace Car 4 speed distributor. Excellent early take-out. Feb 14 67 date. Great date for Pace Car/Festival Car. Original Skin, UN-Restored !!! $400
