Old 05-01-2014, 05:02 PM
Default LS6 Low Rise Intake
I have an LS6 569 intake and can't find a casting date on it. It may have come from a 1973 marine engine. Any enlightenment?
Old 05-01-2014, 05:04 PM
Default Re: LS6 Low Rise Intake
Does it have a riveted on oil splash guard underneath?
Old 05-01-2014, 05:27 PM
Yes,it has the riveted on steel shield.
Old 05-01-2014, 05:46 PM
Drill it out,there should be a date under there.
Old 05-01-2014, 05:50 PM
XXXGoldL34M20's Avatar
The Date code is under the shield. Here is a photo of mine before I put it on the engine.
I decided not to take the shield off mine to just check the date as I was confident it was original to my car anyways and did not want to re-rivet the shield back on. Once it's on the motor who will see the date anyways [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 05-01-2014, 06:41 PM
earntaz earntaz is offline
The only issue with cleaning them is if you were to glass bead the intake -- trash may remain under the heat shield ... I have always (and very carefully) removed the rivets and and cleaned under the shield, then reassembled.
But there are other methods to clean ...
The TAZ
Old 05-01-2014, 08:18 PM
Sand blasting or glass beading without removing the shield is just inviting disaster. Sand is deadly to the whole engine.
Old 05-01-2014, 08:34 PM
Fast67VelleN2O's Avatar
Are the runners numbered on your manifold? If they are its 1971 and later.
Day 2 is Life.
Old 05-01-2014, 09:25 PM
No runner numbers and thanks for the help guys. It is appreciated.
Old 05-02-2014, 12:01 AM
TDW TDW is offline
If you do take the shield off and need new rivets, I have some that I will send you. They came straight from Chevrolet Engine Plant in Flint years ago.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
