Old 04-27-2014, 06:38 PM
TXSS TXSS is offline
Default Unrestored - Survivor 1969 L78 396 375hp X11 Pace
Unrestored - Survivor 1969 L78 396 375hp Z11 Pace Car.
Numbers matching and documented with original dealer invoice, complete owner history and correspondence with the original owner.
This L78 Pace Car is a true unrestored survivor, original paint, all original factory sheet metal, original interior, born with drive-train including L78 396 375hp engine, CX Turbo 400 transmission and BT coded 12 bolt 3:55 posi rear end. The engine is standard bore and has been completely rebuilt as has the transmission, brakes and cooling system using correct GM parts. All have less than 200 miles since being rebuilt. Block was decked at some point but the VIN is clearly stamped by the oil filter. The interior is all factory except for the carpet. All door and quarter glass is original PPG. The paint is 95% original with some minor repaint on the spoiler. Paint is not show quality after 43 years. Has complete factory correct smog system and new Gardner exhaust system. Minor rust at the tips of the fenders and quarter panels. The floors and trunk pan are 100% solid and rust free and still show factory over spray. Many original grease markings still exist on the car. Odometer reads 92,6XX miles. This is a real numbers matching documented survivor 1969 L78 Camaro Pace Car.. Only a hand few still exist. I welcome any serious buyer to inspect the car and the documentation. If you have any questions or need additional pictures please feel free to contact via email or call 713-705-2491. I can send pictures of the documentation. Below please find additional info and a list of options, casting numbers and date codes. You can see more pictures here eBay Thanks Rick
85,000.00
Options:
Power Steering
Power Brakes
Tilt Steering Wheel
Original Factory Rosewood Steering Wheel
Turbo 400 Automatic Transmission
Console
AM Radio
Casting Numbers & Date Codes:
Block 3955272 H148
Intake 3933163 C169
Heads 3919840 C269 / C259
Holley Carburetor 3959164 GE List 4346 8B1
Exhaust manifolds LH 3916178 A269 RH 3909879 A229
CX Turbo 400 Transmission 445
12 Bolt 3:55 Posi-Track BT 0110 G E
Original Harrison Radiator
Correct Factory Smog System
Rally Wheels YJ K19 19/27
Rick
