Old 04-24-2014, 02:41 AM
dlv4540 dlv4540 is offline
Default 1969 Camaro driveshaft
Can anybody tell me if their is a difference in a big block and small block driveshaft for a muncie 4 speed application on a 1969 camaro?
Dennis Vugrinovich
Old 04-24-2014, 02:47 AM
bbbentley's Avatar
Default Re: 1969 Camaro driveshaft
As I understand Dennis, all driveshafts for 69's are the same with one exception being the Turbo 400 (bb applications) has the trunion flanges in line with each other whereas the rest are clocked about 30 degrees apart. Quite a bit of info on CRG forum along with a survey of owner's cars and their observations to document this topic and its variants.
FULL OWNER HISTORY
Old 04-24-2014, 01:33 PM
novadude novadude is offline
Does anyone know why the clocked the u-joints? This goes against everything the text books say about driveshaft design, UNLESS the pinion is offset left/right relative to the tailshaft, along with having a up-down offset. You get into some weird vector math when designing shafts in 3D space that often has the trunnions end up "clocked".
Old 04-24-2014, 01:49 PM
Have never seen a definitive answer.
You can read here:
http://www.camaros.org/forum/index.php?topic=7861.0
That thread has links to even MORE threads on the topic.
Old 04-24-2014, 03:51 PM
Kurt S Kurt S is online now
There's 3 driveshafts in 69.
Manual (SB&BB) and powerglide
TH350
TH400
Kurt S - CRG
Old 04-24-2014, 11:28 PM
69VN's Avatar
69VN 69VN is offline
Het Kurt, off the top of your head could you give the lengths of all 3 driveshafts end to end? Or maybe someone has them listed on another site. Thanks.
SAL
Old 04-25-2014, 02:11 AM
L78 Fred L78 Fred is offline
Sal,
I have them all for your to look at and measure when you stop by.
I can send you pictures of what I have the measurements are written on each in lumber crayon.
Fred
Fred
[email protected]
610-585-4155
WANTED:
