Old 04-09-2014, 08:02 PM
m22mike's Avatar
m22mike m22mike is offline
Default Hurst shifter
69 Camaro 68 69 firebird restored Hurst shifter. All the OE molded on rubber isolaters are still in tact, the core had negligible wear when I got it, probably a early take off.
Plating is cyanide cadmium and will hold up much better that zinc.
The shifter rod was plated by Advance Plating in TN and is perfect. New shift handle 4 piece stainless and rubber isolator installed.
$695.00 plus actual shipping
Old 04-09-2014, 08:29 PM
mockingbird812's Avatar
Default Re: Hurst shifter
OOchee Mama! that is purdy!!! You do NICE work Mikey!!! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Sam...
Old 04-16-2014, 11:45 PM
m22mike's Avatar
Now $625.00
Old 06-04-2014, 02:21 PM
m22mike's Avatar
$600 last bump [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 06-05-2014, 08:36 AM
ban617 ban617 is offline
I have a question about your shifter . Does/Did Hurst make steel replacement bushings to replace the rubber bushings ? Nice shifter.
Old 06-05-2014, 11:09 AM
m22mike's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ban617</div><div class="ubbcode-body">I have a question about your shifter . Does/Did Hurst make steel replacement bushings to replace the rubber bushings ? Nice shifter. </div></div>
Hurst after market shifters had the steel or plastic bushing that could be replaced.
On the OE factory shifter with the molded on rubber isolator there is a rubber replacement bushing that is functional. I get them from Pete Serio @ Precision Pontiac in Columbus Oh.
Shifter bushing
Old 06-16-2014, 10:12 PM
m22mike's Avatar
Sold.
