Old 04-04-2014, 10:44 AM
brent396's Avatar
brent396 brent396 is offline
Default 302 dz 69 heads 202
What's a good month to have for 69 camaro 302 186 202 heads and what are they going for approximately.they have GM valves and been rebuilt in the mid 70's very nice set I think mine are March of 69
1968 ChevyII 396 375,1969 Camaro 396 375 survivor , 1969 Dynamotion Copo Camaro,1968 L 79 ChevyII ,1969 Camaro 427 ratsness ,1967 Chevelle L79
Old 04-04-2014, 12:07 PM
Default Re: 302 dz 69 heads 202
Not really a bad month to have.
Aug 68 through May 69 are most common.
June & July 69 appear less often (normal slow down for model changes).
As for what they are worth, you will see them all over the board.
Some guys prefer to find them with 1.94 valves anyway and have them machined. Also, many guys will want to upgrade to stainless valves, and will just ASSUME they need guides.
I don't know anyone who would buy a pair that was rebuilt in the 70's and try bolting them on.
If they haven't been surfaced, and still have the press in studs, $200 each and up, depending on whether someone is "hot" for the particular date.
http://www.ebay.com/itm/1969-1970-70-Cor...872&vxp=mtr
Old 04-04-2014, 12:15 PM
I prefer 186's with the 1.94 valves and then convert them to 2.02's. This provides nice fresh material for the valve seats. I think it's typical to end up with more $$ in them, but I feel you end up with a better set of heads.
Old 04-04-2014, 12:28 PM
brent396's Avatar
seemed pretty clean looks like the only had one valve job done to them the valves are not sunk in the head exhaust valve still sticks up a little bit date c 26 9 but they have been sitting awhile
Old 04-04-2014, 12:55 PM
Forgot to mention, also a huge plus if they have NOT been ported.
Matched dates is a plus.
Again, <span style="font-weight: bold">minimum</span> $400 for the pair, but you will see guys asking $800 and more.
Old 04-04-2014, 01:44 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: brent396</div><div class="ubbcode-body">What's a good month to have for 69 camaro 302 186 202 heads and what are they going for approximately.they have GM valves and been rebuilt in the mid 70's very nice set I think mine are March of 69</div></div>
any month! can't see the dates when the valve covers are on.
Old 04-04-2014, 03:35 PM
brent396's Avatar
OK thanks how about a oil pan to
Old 04-04-2014, 10:54 PM
If it is an assy line correct oil pan for a Z/28, $300 and up. Have seen them go as high as $500 with the windage tray and studs.
Here is how to tell the difference between the old and the new.
http://www.camaros.net/forums/showth...ht=nos+oil+pan
Old 04-05-2014, 01:43 AM
I have an assembly line oil pan Brent. Some pitting but nice.
Old 04-05-2014, 02:54 AM
brent396's Avatar
Thanks guys
