Old 03-31-2014, 06:13 PM
the427king's Avatar
Default AR torque thruest lugnuts
Does anyone know the exact specs,depth,etc [and where to purchase] a set of lugnuts for a 14 inch original torque thrust rim .
No Fisher priced toys here
Old 03-31-2014, 08:03 PM
BillD BillD is offline
Default Re: AR torque thruest lugnuts
I am guessing you need shanked lugs with a washer? If that is the case then there can be 2 different diameter holes depending on the age of the wheels. The really early design which requires a narrower shank (these lugs are no longer available, as far as I know)or a later design which has a wider shank. I can try to help but need more info.
Old 03-31-2014, 08:25 PM
PxTx's Avatar
PxTx PxTx is offline
I have used these guys to get the lugs I needed, but was unsure of the appropriate design.
http://www.akhwheels.com/
Paul III
Old 03-31-2014, 09:07 PM
the427king's Avatar
Thanks ill try and get the diameter of the holes etc.
Old 03-31-2014, 11:43 PM
I'd call these guys:
http://www.ebay.com/itm/20-MAG-LUG-NUTS-...bcb&vxp=mtr
