Old 03-24-2014, 06:36 PM
Default Buffer Question
A while back I purchased a Craftsman 7" buffer. Recently I hit the local paint shop and purchsed the 3M buffer pad attachment that should screw right onto the buffer. But Craftsman apparently decided to use a smaller threaded spindle than the 3M pad is threaded for.
Has anyone here found an adaptor to make this work? I'm thinking that I will try to make a double threaded sleeve to make the conversion, but if someone has already solved this problem I won't reinvent the wheel (no pun intended).
Blair
1968 L71 Corvette Coupe
1967 L30 Chevelle Malibu
