Old 03-11-2014, 10:49 PM
69VN's Avatar
69VN 69VN is offline
Default Original 12 Bolt Rear Brake Hose, Bracket, Brass T
This is an original rear brake hose, steel mounting bracket and brass "T" removed from my 12 bolt a few years back. Has some rust on the fittings. Bracket appears to be in good shape (just needs bead blasting). Brass "T" block looks to be in good shape as well. This came on my '69 rearend but the brass "T" block and the steel bracket appear to be the ones used on the '67-'68 model year...??? Can anyone confirm this by looking at the photos? *Asking $35 w/shipping included to lower 48 states. PM me with any questions or answers!
Thanks for your help,
SAL
