Old 03-06-2014, 02:54 AM
BLACKLS5 BLACKLS5 is offline
Default Turbo 400 vacuum line
Can someone tell me if the metal vacuum line for a turbo 400 in a '70 Chevelle should have a mounting ear on it? Everything I find listed from the restoration places don't have it but the assembly manual sure makes it look like it should have a mounting tab that bolts to the back of the engine. I would think it would be mounted rigid with the short hoses on each end, but I could be wrong. Any insight would be appreciated. Thanks.
Old 03-06-2014, 09:03 AM
Donnie's Avatar
Donnie Donnie is offline
Default Re: Turbo 400 vacuum line
yes its spot welded to the line.
the repops dont have it. they want you to use one of those wrap around clips like on the brake and fuel lines. and it dont hold to well.
find an original and clean it up.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 03-07-2014, 01:40 AM
Donnie, Thanks for the reply. Heaven forbid someone reproducing a part that is accurate... Troy.
