Old 03-04-2014, 02:32 AM
rare4k rare4k is offline
Default emerald turquoise On EBay 03/03/14 MO
67 Camaro SS 396 375 horse L78 4K code. One of 1138 4K cars produced of which only 249 are known to have survived. One of two known in this color. Very rare emerald turquoise. Please read the whole add for condition. A very easy restoration with a lot of the rare expensive parts original and intact and a solid body.
This car has not run since 1990 not licensed since 1986. The engine and transmission is a CE LS6 454 dated in 1970 coupled to a 325 case 1965 S vin 4 speed Muncie with Hurst shifter. So not original to the car. The rear axle is a PJ coded optional ratio 3.73 12 bolt positraction. Original Ring and pinion dated 3 67. The square bar traction bar is still in its original placement.
The underhood is in mostly otherwise original condition with the optional manual disc brakes, 467 master cylinder, original 23 inch radiator, factory original rare shroud, big block heater box ect. The non original 454 still retains the Camaro's original 1170 distributor dated May 67 but the carb is a 1970 Ford CJ 780 Holley Apparently worth about $500 as a core.
The interior is factory black in very good survivor condition. The drivers seat was reupholstered previously to covers being available and should be redone. The carpet is still very good. remaining seats and dash pad very good. Console and gauges are complete and good. The original factory tach is 6K red and 7K as it should be. Miles shown believed to be original and the doors shut as if it was. Rear package tray needs replaced.
The body is very rare color Emerald Turquoise. Repainted once many years ago. The quarters have some rust and should be repaired. The right front fender has rust both by the battery box and lower rear corner. That is the only rust on the exterior panel I have observed, The trunk has surface rust on the floor and a small repair needed on the right shock tower. Otherwise the floors are great. The front frame is surface rust only.
The trim tag is original and never removed. As is the VIN tag. A believed to be original 840 head dated May is included in the sale as is the rallys that were on the car. They are not DG nor will they hold air. The wheels tires that are on the car are NOT included, are G 70s are 14 x 7. Although they can be purchased for an additional $1000$. The window trim is included in the trunk
