Old 02-27-2014, 10:34 AM
twertsy twertsy is offline
Default Transmission Choices
Morning all. I've been attempting to research manual transmissions for my GTO build, with little luck gathering the information to make a decision. So, I thought I'd ask your thoughts and recommendations. This is a "pro touring" build, with a butler 505 and anticipated ~750 HP. It has a 4:11 12-bolt posi. Who builds a manual transmission that you would recommend that can safely handle the HP/torque? I'm thinking at least a 5 speed to compensate for the gearing but possibly a 6 speed? Any thoughts/recommendations greatly appreciated!
Old 02-27-2014, 11:26 AM
PxTx's Avatar
PxTx PxTx is offline
Default Re: Transmission Choices
How many gears do you need with 750hp? I like the simplicity of a 4 speed and hate tge way internal rail shifters feel. Autogear 4 speed maybe? You could throw in a Gear Vendors OD unit if you gear it low enough to require one.
Paul III
Old 02-27-2014, 12:02 PM
Well, when I ask it to go, I want it to go. On the flip side, I want to be able to drive a hundred miles on I-95 to a car show at something short of 8000 RPM.....
Old 02-27-2014, 12:41 PM
tremic 5 speed.
I believe they are rated for 650 hp.
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 02-27-2014, 04:28 PM
AutumngoldL78 AutumngoldL78 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: pxtx</div><div class="ubbcode-body">How many gears do you need with 750hp? I like the simplicity of a 4 speed and hate tge way internal rail shifters feel. Autogear 4 speed maybe? You could throw in a Gear Vendors OD unit if you gear it low enough to require one. </div></div>
X2
