Old 02-24-2014, 12:13 PM
69VN's Avatar
69VN 69VN is offline
Default Used Original 1969 Rear Parking Brake Levers LH/RH
These are original used parking brake levers/brake shoe bars LH/RH removed from my 1969 12 bolt rearend. Not bad condition although some tiny pitting throughout, but very solid on all pieces. The two brake springs however are reproduction (original springs were bad). If I can find the two guide plates they will be included also. These will fit 1967-69 Camaro and Firebird. Maybe used on other models as well, just check your application. *Asking $30 w/shipping included to lower 48 states. PM me with any questions. Thanks.
