Old 02-19-2014, 09:23 PM
foster foster is offline
Default 1969 pontiac judge
any body knows if this water pump is the right one for the 1969 judge only part# 9796351 looks to be dated E 14 9 J
1967 SS CHEVELLE SURVIVOR
1968 SS MATADOR 396 CAMARO
1967 CAMARO SURVIVOR
Old 02-20-2014, 01:46 AM
442w30 442w30 is offline
Default Re: 1969 pontiac judge
My info from Eric White's GTO book shows it to be one of three available for the GTO. The one you show is the early version. Whether it's the one that is supposed to go with Ram Air cars, I dunno.
Old 02-20-2014, 03:06 AM
John Brown's Avatar
69 Pontiacs used at least two different water pumps. One had a hub height of 4 15/32, the other had a hub height of 3 31/32. No doubt there was a different set of pulleys depending on which pump was used. It's been a long time since I bought my 69 428 Catalina (mid 69), but I believe the reason for the change was because Pontiac improved the water pump with a larger bearing and changed the overall height at the same time.
John Brown
Old 03-04-2014, 12:19 PM
NOTIME NOTIME is offline
Yes, that is the correct pump.
Owner Supercar Creations
69 L-89 SS Camaro 4 spd
69 RA IV Judge 4 spd
70 Judge 4 spd barn find
71 Judge 4spd
70 Chevelle SS 396 4spd
72 Cheyenne Super 402
70 Caprice LS-5
99 WS-6 TA 6 spd
70 Torino SCJ Dragpack 4 spd.
Old 03-05-2014, 04:58 PM
tjs44 tjs44 is offline
did the GTOs use 2 diff length or did the bird use a diff?Tom
Old 03-06-2014, 07:54 PM
Not sure about the bird but they say there was a late version of the 69 water pump that was longer and had different pulleys but ive never seen one. The longer pump part # ends in 124 and started in 70 or in late 69 as some believe, and may be true, and ran through 71 . Most 69s had the 351 cast #.
71 Judge 4spd
70 Caprice LS-5
99 WS-6 TA 6 spd
