Old 02-19-2014, 09:21 PM
Ngtflyr Ngtflyr is offline
Default 1970 Chevelle Upper A-Arms
What is correct on a 70 Chevelle upper A-Arm as far as the shaft goes.
My 69 Chevelle and 69 Camaro have bolts retaining the shaft to the upper A-arm. The upper A-arm that came off my 70 Chevelle had bolts as well. The car has been apart before so I just want to make sure it's correct before I assemble everything.
I am seeing two different types, is it correct to have nuts on the ends of the shaft that goes through the A-arm, or is it a female type end with a bolt that holds everything in place?
This pic has a bolt securing the ends of the shaft(this is what is on my unrestored 69 chevelle and restored 69 camaro):
This pic shows the other option and it has a nut securing the ends of the shaft(this pic was taken off a parts supplier website. I know for sure that GTOs have this type of setup:
The pictures aren't great but should help.
Dave
