Old 02-09-2014, 03:52 PM
enio45 enio45 is offline
Default Exhaust Manifold Washers - SB
Is there any opinion on this ebay ad related to the fact that only the outside ports get the washers?
Particularly i'm thinking about 69Z/28's
ebay exh washers
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-09-2014, 04:07 PM
Default Re: Exhaust Manifold Washers - SB
Hey Eddie, try this Click Here
Old 02-09-2014, 04:16 PM
thanks - not sure what I did wrong???
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-09-2014, 04:22 PM
It's been my understanding that only the bolts that got the french locks got the washers.
Old 02-09-2014, 04:40 PM
really?? so the sequence is the bolt, French lock then the washer before u install the exh manifold???
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-09-2014, 05:34 PM
Nope. The washer is against the manifold, then the french lock is under the bolt head.
Maybe we're saying the same thing............??
Old 02-09-2014, 06:14 PM
My nova has the lock washer in front of the french lock against the exhaust manifold. So its the bolt, lock washer, french lock and onto the manifold. I guess if it was the other way around the french lock would not allow a good seat on the manifold maybe.
Old 02-09-2014, 08:03 PM
Sam,
It's not a lock washer; it's a thick flat washer. The french lock needs to be under the bolt head, against the flats, so it can do its job by preventing the bolt to turn.
Old 02-09-2014, 08:48 PM
I am with you Verne. I guess whoever did my car did it there way. Probably will see this done on survivor cars both ways. The tabs need to be bent over the heads of the bolts like you said.
Old 02-09-2014, 09:24 PM
Plowman's Avatar
Plowman Plowman is offline
Are they &quot;Circle Head Exhaust Manifold Bolts&quot;.
