Old 01-26-2014, 04:04 PM
Default 12 bolt yoke, 69 up
I have two yokes. BOTH of them have the same defect. The tabs that center the u-joint are too far apart making it virtually impossible to get the u-joint centered, resulting in vibration. I have tried GM u-joints as well as aftermarket. All same result. My Z is a blast to drive around town, but frustrating at highway speeds because of this vibration.
I need a good used or even a new yoke reasonably priced. Please be sure the locating pins actually center the u-joint. 69 and up made for straps, not u bolts, and with the seal guard.
PM if you have one.
