Old 01-22-2014, 11:21 PM
SeattleCarGuy SeattleCarGuy is offline
Default Correct paint for '69 Nova hood hinges and latch
Does anyone know of the correct spray paint color to use for '69 Nova hood hinges and the hood latch assembly? Or, do these have to go out for plating?
Paul
Paul
'62 Bel Air 409/409
'63 Impala SS 409/340 convertible
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Old 01-22-2014, 11:33 PM
69VN's Avatar
69VN 69VN is offline
Default Re: Correct paint for '69 Nova hood hinges and latch
I don't believe that hood hinges were painted whether it was a Nova, Camaro or Chevelle etc.. They had a dark gray phosphate finish on them when installed. Not sure who does this type of finishing. Maybe someone else reading this thread can help out. Hope this helps.
SAL
Old 01-23-2014, 12:12 AM
Paul, Steve Gregori www.brakeboosters.com is fairly close to you and he does a great job. I request a very dark grey phosphate and he always comes through. They also have a slight crystalized texture which also resembles the original finish. Unfortunately I do not have any hinge specific photos but here is an installed photo of Dana's hinges. I have matched this finish to a pair of NOS and they are pretty damn close.
Old 01-23-2014, 12:32 AM
If you are looking for a "home brewed" solution...there are some spray can choices..
http://www.eastwood.com/eastwood-zin...e-aerosol.html
last set I did were media blasted first...surface had a slight texture to it...I primed with a grey primer...then a light coat of detail grey and a finish coat of the Eastwood product...they looked pretty nice. A high end resto probably deserves the full monty...but, this will work for most folks.
wilma
Old 01-23-2014, 11:48 AM
JRSully JRSully is offline
Brian at Supercar workshop plated mine, if you want to go that route. They came back perfect
71 Porsche 911 Targa
Old 01-23-2014, 12:33 PM
Jerry MacNeish did mine 12 years ago and they still look real nice.
Old 01-23-2014, 01:07 PM
iluv69s iluv69s is offline
you can do them yourself if you are a bit handy.. somone here has a thread?? charley?
Old 01-23-2014, 04:11 PM
Thanks everyone for the tips. I have my brake booster with Steve Gregori at the moment. I will check with him on his pricing for doing them. May also consider doing myself with the Eastwood products. We'll see....
Thanks again!
Paul
'62 Bel Air 409/409
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Old 01-23-2014, 04:12 PM
edcar70 edcar70 is offline
I did my own with solution from Palmetto industries and a turkey fryer. Zinc Phosphate is a dark grey and Manganese phosphate is black which works perfect for most of the bolts on the car. ed
1970 Camaro L-78
1970 Chevelle L78
2015 Z-06, 2008 Z-06
Old 01-23-2014, 04:29 PM
Paul, I have used the Eastwood spray phosphate before on some low end parts I have done and in reality it looks really good. I typically cover the parts with a good coat of paint and then put on a very dry coat holding the can over the part about 2' away which gives it a texture. It really looks good when done but it is a spray bomb none the less.
